Help with making a THR to ELEV mix, 9C
PROG.MIX1
MIX>ON
MAS>THRO
SLV>ELEV
LINK>OFF
TRIM>OFF
SW>A
POS>NULL
RATE> DOWN 0% UP XX% (sets elevator travel)
you may have to swap these numbers depending on your servo setup
OFFSET 0
The offset controls where the mix "kicks in" in relation to throttle setting. With the cursor over offset, put the stick in whatever position you want the mix to be active and press the dial to set.
0 offset has mix for full range of thr stick, 50 offset mix only above 50% throt.
