RE: just a small concept....
no no no, you've misunderstood what i've said, let em take a pic to explain what i meant there (the pics on the muggy, but i got th problem with both the LST2 and mug)
the pre load adjustment hits the shock tower when the shocks are upright, as is the shock absorbers are facing up, and you can only get full adjustment of the pre load with the shock absorbers facing down, with the shaft pointing up, i wasnt saying the shocks sit more vertical on the LST2 with the muggy shock tower.
