RCU Forums - View Single Post - NQD Cat--Outboard conversion
Old 10-08-2007 | 09:01 AM
  #161
CadillacDTS2001's Avatar
CadillacDTS2001
Default RE: NQD Cat--Outboard conversion
ORIGINAL: j.m.
I'm just going on the fact that electric motors have more torque than a similarly sized nitro motor. And a 12 turn motor usually has alot of rpm, so it should work. And what kind of st do you have?
How is the even possible?
How can you compare a electric motor to a similar sized nitro. Are you talking in actual size like dimensions? because if you are then forget about it.
Two 12 turn motor will not get you as fast as a .21 boat. I have no idea where you pull this stuff out ( i have a good guess however) but it is just so wrong its not even laughable.
Life is hard. . . compared to what ?
12 turn motor has a lot of rpm. . . compared to what ? You can't just say these things and expect it to be.
if you want to discuss nitro stadium trucks i suggest you take it to the forum.
