ORIGINAL: frenchie79
You know you just gave me an idea-I think I will put a small "T" fitting in then attach a small peice of line to the cross portion of the "T" with a fuel dot that can be pulled off and fueled from. I don't think it will flood the engine because the fuel should take the easiest path. ??? anyone out their try this.
I did this with an inverted Saito 65. I would close the throttle barrel all the way before filling. A little fuel would make it into the engine, just enough for a good wet prime. Turn engine over now to make sure it won't hydraulic lock.
Defueling through the tee took a little longer because of the airleak at the carb.
Thanks for the reminder! I was wondering about fueling on a 25fx going into my 15Shrike. It's a tight fit with the rear needle.
