RCU Forums - View Single Post - Dymond 52" Tiger Moth Build Thread
Old 10-09-2007 | 02:01 AM
tmulder
My Feedback: (7)
Default RE: Dymond 52" Tiger moth
I glued the tail surfaces to the fuselage, added the control horns, hooked up all the linkages and tested and adjusted the throws. Since the rudder is so high, I was not able to use the flexible sping tail wheel hookup by Sullivan. Instead I added the Du-Bro servo override setup on the rudder control rod. Again, I used carbon fiber for the control rods.
ID:	779362   Click image for larger version
ID:	779363   Click image for larger version
ID:	779364   Click image for larger version
