RCU Forums - View Single Post - Dymond 52" Tiger Moth Build Thread
Old 10-09-2007 | 02:43 AM
tmulder
My Feedback: (7)
Default RE: Dymond 52" Tiger moth
After the detail work on the cowling, I made holes for the needle valve and the low idle adjustment. I figure once the engine was installed and the cowl on, it would be too much of a pain to adjust the low idle. You may not want to do this for looks, but with the muffler and prop on, I did not want to hassle with it. This is a new Saito engine and I know I will have to make subtle adjustments. Taping card stock to the fuselage, I made the marks for these holes along with the hole for the muffler. Reattaching the cowling, I transfer the marks and then cut out the holes with a Dremel tool.
More to come!
ID:	779383   Click image for larger version
ID:	779384   Click image for larger version
ID:	779385   Click image for larger version
