RE: How to remove a prop hub
I'm in the middle of taking apart 2 PB400.
The mag hub came off easily on the 1st one and won't budge on the 2nd one.
You should be able to put the nut back on flush with the shaft and wack it with a hammer and it should come loose.
One more thing, you have to let the motor hang by the hub whe you hit it.
