RE: Matrix buggy clutch ?'s V.3!
Good thinking MattyB, Yes you should hit the inside of the clutchbell with brake cleaner liberally then sand it out with 500 grit paper pulling the paper out the side of the bell so most of the scratch marks are across the shoe's path. then hose down the clutchbell again with brake cleaner to get ALL of the debris out. Dont be shy with the brake cleaner!!
Hope this helps!
