RCU Forums - View Single Post - Robart Hinge ??
Thread: Robart Hinge ??
Old 03-25-2003 | 04:36 AM
Giant Scale
Default Robart Hinge ??
I would disconnect the linkage from the surface. Fully extend the surface and use a hypodermic syringe with a needle to inject some glue into the hinge pocket. Pacer maked hinge glue that has a small tip that should fit into the gap. As an added bit of insurance I would seal the hinge gap with either covering or 3m blenderm surgical tape. The pacer hinge glue works very well I have actually had hinges break at the pin before they came loose from the control surface.
