RCU Forums - View Single Post - Nitro models pusher Bobcat?
Old 10-10-2007 | 02:37 PM
  #2319
opjose's Avatar
opjose
Default RE: Nitro models pusher Bobcat?
ORIGINAL: RCplaneflyer14
After looking at pictures of the nitro version of this plane, I see the engine is mounted without an engine mount, so how would I mount an electric motor? Is there a firewall I can bolt it to?
No firewall.
The "LIP" we mount the engines onto is VERY VERY hard wood. ( They did this right on this plane. ).
So you could bolt on any sort of mount you want to come up with.
A pair of hardwood blocks cut to size then epoxied into the fuse works fine, adjust as needed for an electric.
