RCU Forums - View Single Post - Antenna Placement Question
Old 03-26-2003 | 02:53 AM
mscic-RCU's Avatar
mscic-RCU
Default Antenna Placement Question
I use a rubber band hooked to the tailwheel bracket if you have one, or I stick a t-pin in the back of the fuselage. I take a servo arm that you cut off, three holes at least, cut a slot to the first hole to form a hook and weave the antenna wire into the other two holes and hook it to the rubber band to keep it taught. Works great.
