RCU Forums - View Single Post - Is this a bad idea?
Old 10-14-2007 | 01:21 AM
Bad_Daddy's Avatar
Bad_Daddy
Default RE: Is this a bad idea?
Setting a SLIGHT amount of down trim (flaps) to both ailerons might not be a bad idea, especially if they are slightly up (spoilers) right now. But adjust the linkage so they are no more than 1/8" below the T.E. of the wing, probably 1/16" would be better. Loose linkage or sloppy hinges could be allowing the ailerons to fly in a slightly upward condition under normal flight.
