 Is this a bad idea? >
Is this a bad idea?
Is this a bad idea?
Old 10-13-2007 | 02:39 PM
Default Is this a bad idea?
Well, my plane extra 300 likes to come in a bit hot for landings, otherwise it just drops out of the sky. Would it be bad to add a little down ailerons to solve this issue? I don't have mixing capabilities so this "down ailerons" would be persistent throughout the entire flight.
Opinions please.
Old 10-13-2007 | 03:36 PM
Default RE: Is this a bad idea?
Hi!
Bad idea! Better do something about the weight!
Old 10-13-2007 | 06:14 PM
Mr67Stang's Avatar
You did not mention which Extra 300 you have. Since this is the beginners forum I would guess you probably have the Park Flyers Extra 300 that advertizes, "Hover at 1/2 throttle"??? If it is I hope you have some experience prior to that plane. What will likely happen if you set your ailerons up the way you describe will be an adverse downward pitch of the nose. I know that does not make sence however, all but one of my models will do this when I apply Flapperons without mixxing it with up elevator. Since you do not have the ability to mix I would encourage you to learn to land it hot as opossed to adjusting the ailerons and elevator. Now I have no idea of your previous experience so forgive me if I presume to much.
Best of luck with whatever you decide.
Old 10-13-2007 | 07:32 PM
w8ye's Avatar
My Feedback: (16)
Dropping ailerons would cause the plane to drop one wing when it did stall.
Old 10-13-2007 | 08:26 PM
MinnFlyer's Avatar
Re-check your CG. The problem you describe sounds like a classic case of either the plane is too heavy, or it's too nose heavy.
Old 10-13-2007 | 09:23 PM
Mr67Stang's Avatar
ORIGINAL: MinnFlyer
Hey Minn, If he has the Extra 300 I think he does, the flight charactoristics he describes is exactly what others have complained about that plane. It just stops flying unless your in the throttle with it. Probably to heavy because a 3D plane should be happy going slow.
Old 10-13-2007 | 09:31 PM
w8ye's Avatar
My Feedback: (16)
My experience with these is you have to bring them across the fence real hot and let them play out just above the ground and drop them on the deck the last few inches.
Old 10-14-2007 | 12:46 AM
TexasAirBoss's Avatar
My Feedback: (22)
Often "hot airplanes" will slow down in experienced hands.
Describe your landing technique. I would hope you say that you slow the plane using the elevator and that you control the sink rate with throttle. Remember . when you slow down using the elevator, you increase the angle of attack, this causes greater lift, but greater drag, therefore you must now add power to overcome the additional drag.
Chopping power and gliding in is not an effective way of slowing an airplane.
Old 10-14-2007 | 01:21 AM
Bad_Daddy's Avatar
Setting a SLIGHT amount of down trim (flaps) to both ailerons might not be a bad idea, especially if they are slightly up (spoilers) right now. But adjust the linkage so they are no more than 1/8" below the T.E. of the wing, probably 1/16" would be better. Loose linkage or sloppy hinges could be allowing the ailerons to fly in a slightly upward condition under normal flight.
Old 10-14-2007 | 10:09 AM
bad idea ,it would be like having wash in built into the wing and when the tip does stall low and slow to the ground the resulting tip stall and snap will be almost impossible to recover from.
Old 10-14-2007 | 10:14 AM
w8ye's Avatar
My Feedback: (16)
You want the angle of attack of the wing less at the tips than at the root. This is done so the root of the wing stalls before the tip. Therefore you have a plane that stalls straight down without dropping a wing.
To droop the ailerons has the same effect as twisting the leading edge of the wing up at the tips. With the greater angle of attack at the tips, one wing tip will stall first, every time, causing the plane to snap roll into the ground at landing.
Old 10-14-2007 | 12:12 PM
broke_n_bummin's Avatar
ORIGINAL: Mr67Stang
I used to have that problem until I started playing with the CG. On all my 3D planes, I have the CG back just to the point that when I apply flapperons, the plane almost comes to a standstill. Most of the time, this is just behind the recommended CG (also helps in a hover).
If you could move your CG back just a little at a time, I would be willing to bet that the plane would fly much slower. Being that this post is in the beginners forum, I would suggest staying within the recommended limits until you are comfortable with the change. I like flapperons, but I really only need them on a plane outfitted with a 2 stroke engine, and I never use them for landing. Flapperons take away the effectiveness of the ailerons.
Old 10-14-2007 | 12:45 PM
w8ye's Avatar
My Feedback: (16)
If you get the CG too far back, the plane will become squirrelly at landing. So as you are adding tail weight, when the elevator starts becoming difficult for you when you are trying to land, you have gone just a little too far with moving your center of gravity back.
Old 10-14-2007 | 02:17 PM
Assuming you are using a nitro engine, you might try a wood prop before adding any weight to the rear of the plane. The wood props are quite a bit lighter than nylon composite or plastic. And it is true ... if you get the CG too far back, the elevator will have too much authority. I can dial it down with my dual rates, but it still takes a bit of finnesse and a whole lot of practice. You should be ok though if you start off staying within the Mfgr CG range. I didn't mean to sound like you should go straight for the throat and move the CG 2 or 3 inches back from where it is suggested. As a matter of fact, none of my planes have gone past 1/4 inch from the range the manual suggests. I just like landing tailwheel first.
Old 10-14-2007 | 02:25 PM
w8ye's Avatar
My Feedback: (16)
I was just trying to give the original poster a feel for making his own adjustments along the lines of your suggestion.
I didn't mean to imply anthing.
Jim
Old 10-18-2007 | 05:35 PM
if the plane is not over weight then reducing the prop pitch by 1 will slow down landings.
