RCU Forums - View Single Post - Need 4 cycle valves
Old 10-14-2007 | 02:07 AM
Motorboy's Avatar
Motorboy
Default RE: Need 4 cycle valves
To buy ready maked valve can have problem with right length and diameter of valve stem when the valvediameter are right.
It is better to make own valve of stainless steel (no rust and extremely tough).
The valve diameter are calculated by valve lift, also are valvelift 1/4 of valve diameter. The formula: Valvediameter:4=valve lift. Find how high are valvelift in your camshaft in the 4 cylinder engine before you can make own valve with right valvediameter.
