RCU Forums - View Single Post - Nitro models pusher Bobcat?
Old 10-14-2007 | 07:28 AM
  #2355
thebluemax's Avatar
thebluemax
My Feedback: (151)
Default RE: Nitro models pusher Bobcat?
ORIGINAL: opjose
ORIGINAL: thebluemax
The canopy looks to be another problem. I trimmed it along the lines they had marked on there. When it sits on the fuse there is not much room on the side of the fuse underneath the canopy to secure it witth screws. I can do one on the top front and top rear but the sides do not have much to grab.
Check out the "quick release" canopy mount I made for the Bobcat .25. Very easy to do.
You could use two instead of one like I did.
The magnets are totally unnecessary.
ORIGINAL: Flyboy Dave
....I'm old fashoned.....I use small screws and some automotive trim tape
to seal the deal.....It keeps air from getting under the canopy and working
it loose. It peels right off if you need to get beck inside later.
FBD.
Thanks guys for the tips. I was thinkiing I would have to do it the old fashion root as I am that way as well. I might try and do a combination of the two with the quick connect as additional support. I am going to try and get it worked out today.
