RCU Forums - View Single Post - tamiya pershing upper hull question
Old 10-14-2007 | 02:25 PM
pcomm1
Default RE: tamiya pershing upper hull question
ORIGINAL: tantank
Hello I have just finished building my tamiya pershing tank. It is ready to go. I have a question concernig how to close the gap in the front section between the upper and lower hull. It does not close tight. Any help is welcomed. Thanks
Other Pershing things to check:
Keep the space under the turret rotation motor unit clear.
Also make sure the wiring for the hull machine gun and lights (if installed) are not keeping the front of the glacis plate from fitting snuggly.
Use the rear turret space to store the long wire leads, so as to not let them sit atop the DMDs.
John
ID:	782819   Click image for larger version
