ORIGINAL: Stickbuilder
ORIGINAL: littlecrankshaf
ORIGINAL: JUGFLIER
I don't know if DVP in D5 are elected or coronated.
That's one thing that you need not worry too much about.
Bill, AMA 4720
Stickbuilder,
Forgive me, but You are starting to sound like STL. That is truely an odd statement considering Jug has more to gain than most. Who knows he might actually get a fair shake from another D5 VP. Would you be so kind and explain your reasoning?
I would be most happy to respond, but due to the climate in the AMA forums of late, I would not like to see any more threads locked down, due to the AMABPA (AMA BASHERS PROTECTION ASSOCIATION).
Bill, AMA 4720
Stick,
Just because STL or Red and a few others label some of us AMA bashers does not make it true. That is just a defensive ploy of misdirection of any weak position they are trying to defend at the time. Do not fall for it. Do not start using it also. You can explain yourself without bashing me or RCU if you just wanted to. Similar misdirection as with your previous response is bad form. You are learning bad habits from the few here that use the technique. I feel you are better than that!
