RE: Nitro models pusher Bobcat?
Yeah it otherwise balloons a lot when you hit the spoilerons.
I have it flying level when I hit the switch, but I am going to set it to lower the ballooning just a bit, but not eliminate it as a compromise.
As you've said I find that I'm fighting the elevator too much.
Since I have the nose gear on a seperate channel, I've been contemplating throwing in an "airbrake" switch that throws both rudders outward and pushes the nose down ( throwing the rudders "out" causes the nose to come up!!! ) to help slow the plane down when it is on the ground.
I'm often running the full length of our 600 foor field getting this thing stopped.
