The gear set up. I have the aileron servos and wires set up first then the throttle servo, that's easy. Then I move things around to get the CG. I assemble the complete plane while in the bones and make sure everything works correctly and is in the right place then hard mount everything, take the plane apart, finish sand and cover.
Building the plane is easy, setting it up takes A while.
