RE: Kill Switch?
Of the available electronic kill switches, I like the RCAT systems the best..... aside from that, use a spare servo to choke the engine. Not only would you then not have to choke the engine through your cowl with other methods (you could use your transmitter), you can also choke the engine with the same switch on your transmitter for a kill switch.
Chad
