RCU Forums - View Single Post - Lost plane device
Old 10-17-2007 | 10:06 AM
w8ye's Avatar
w8ye
My Feedback: (16)
Default RE: Lost plane device
The original Hobbico lost plane device should work as well with PCM and 2.4 Ghz radios as the FM analog types.
The device looks for a change in the signal to reset it's timer. If the signal stays steady, the device will time out and start beeping.
I must say the the thing is frustrating at first. Before you get your plane started and taxiing out the darn thing is giving the warning and I have to move the ailerons to reset the timer before take off. You get used to it after a few flights. Every time you get close to the transmitter, you wiggle the ailerons.
I suppose on a three channel outfit you would hook it into the rudder channel?
