RCU Forums - View Single Post - TREX SE V2 Build Log
Old 10-17-2007 | 10:43 AM
heliaction's Avatar
heliaction
Default RE: TREX SE V2 Build Log
Its not right...... If you look at the diagram you will see 2 dimensions on the flybar control arm, 1 is 18.25 and the other 20.75. Note that the pic shows the short side is leading while the long is trailing. What it appears in the fist pic (when you first asked this) and the last pic from you last post is you have one installed the wrong way round. One is correct while the other appear not to be.
I hope you understand what im trying to say.
