RCU Forums - View Single Post - TREX SE V2 Build Log
Old 10-17-2007 | 03:46 PM
heliaction's Avatar
heliaction
Default RE: TREX SE V2 Build Log
I cant express myself how strongly i agree with P47 Jug - Al, good quality tools will be like "Brufen 600" to a mild headache. You have spent good money on your heli, please spend good money on a few simple tools. The small screwdriver and small allen key are the most used. I got myself a set of align tools including ball link pliers, which are a must.
Not sure what holes you have in your case but please inform?.
The blue locktite supplied with the kit is good, im not sure what Finless uses but i have red "221 LOCTITE" which is low strength and vibration proof. It appears to be similar to the provided blue align stuff. Basically you want only a little hold, too much hold will cause more damage than good. I truly believe as a commercial heli pilot and FAA licenced engineer the "221 loctite" is equivalent to the supplied T43, however use the recpective locktight as decribed in the manual.....ie use T43 or equivelent in it resective place and use the R48 where the manual state it's use.
