ORIGINAL: alfredbmor
Rafael: you are free to think that is a copy and paste job, just try to read the manuals or go further and make a good investigative job then you may come back and post whatever you want. This thread as I mentioned earlier is intended for those who have a similar equipment and as a guide to program their radios, I surely do not need to argue because it does not lead anywhere if you have a positive comment to share that could help others with the programming of their JR8103 radios with their Trex SA then post it, otherwise keep it to your self.
Dude, calm down. I am not trying to be anything but helpful here. Obviously you are a newbie and you just followed a cookie cutter recipie to programming you radio. Obviously you don't know where those numbers came from. I'm trying to help you understand (by being critical of your post) the reason behind the numbers.
If you don't like it, I'll go away. If you don't want to learn from experienced pilots, I'll go away. I just disagree with your procedure and noted it so people have an option of following your procedure or mine. Either way, I'm out of here, oviously you did not like my comments.
Either way, the entire procedure is noted in video at the Helifreak on one of Finless videos.
Rafael
