RE: Replacing a Servo
yes, after you plug the servo in and turn everything on, make sure that the horn on the servo is at its middle travel. If not, see if you can adjust by taking the plastic servo horn off and trying to line it up as close to middle.
Then check for correct rotation and flight controls, and you're ready.
Michael
