Walkera Helis - Dragonfly, etc.. Discuss Walkera Dragonfly Helis and any Walkera products in this forum
Replacing a Servo
Old 10-19-2007 | 12:51 PM
Default Replacing a Servo
Hi everyone,
I have to replace a servo on my Walkera 5#8. I'm new to the RC world and I sure could use your help.
Here is a video of what the Bad servo is doing. I was told that the gear-stop broke that's why it keeps spinning.
[link=http://www.tablehockeypro.com/img2/WalkeraServo.htm]http://www.tablehockeypro.com/img2/WalkeraServo.htm[/link]
With new servo this is what I think I need to do...
1-Plug the servo into the receiver correctly
2-plug in the battery to the helicopter
3-Turn on the Transmitter/controller and let the heli and controller initiate communication.
At this point the servo should be in the correct position and should be able to attach servo pull rod to the pinion on the servo and make sure the swashplate is straight.
Is this the correct procedure? Thank you in advance for your time.
~Paul
Old 10-19-2007 | 01:42 PM
Default RE: Replacing a Servo
yes, after you plug the servo in and turn everything on, make sure that the horn on the servo is at its middle travel. If not, see if you can adjust by taking the plastic servo horn off and trying to line it up as close to middle.
Then check for correct rotation and flight controls, and you're ready.
Michael
Old 10-19-2007 | 02:05 PM
Thank so much Michael.
This is a great RC forum. [sm=thumbup.gif]
~Paul
Old 10-19-2007 | 02:22 PM
Yes, i find RCU the best also.
Old 11-05-2007 | 11:15 AM
try flyermate A6.0 servo, it is a 6 grams servo, much lighter than the original 9 grams servo.
you can find in ebay
