RCU Forums - View Single Post - Centerline on firewall
Old 10-20-2007 | 12:33 AM
plugin's Avatar
plugin
Default RE: Centerline on firewall
I cannot compensate with washers because its a side mounted engine. I already drilled the holes and I'm off the supposed centerline by only 3/32" which I'll assume its ok. If it seems awkward when I fly it, I'll just expand the screw slot on the mount a bit so I can slide the mount just a tad to compensate those 3/32"
