Centerline on firewall
I'm mounting a .91fx on a GP Extra .60. The holes for the engine mount are located at the borderline of the top of the firewall. I'd like to drill them about 1/8" away from where they are currently marked to be. Is it a really bad idea to do this as this would shift the engine's center line 1/8" away from the supposed centerline on the firewall?
I wouldn't think that 1/8" low would make that much difference but the spinner may not be centered on the cowl. Have you looked at other motor mounts, IE the Dave Brown ones will let you squeze a mount where you don't really have room.
If the firewall is capped with a balsa top, you my have to do what I had to do with a Great Planes Super Aeromaster. I made a new firewall that was a full cross section of the front of the fuselage out of 1/4 aircraft ply. This repaced a rectangle firewall with a balsa former on top. That gave me just enough real meat to get the engine mounted. The plans called for a 91 or 120 four stroke, and I had to shoe horn the 91 in. I picked up my 120 and it just screamed NO, No way.
Don
Don
Instead of altering the centerline, why don't you get another motor mount and re-set the mounting holes. I do this all the time when I change motors and the old mount doesn't align with the new motor. While you can make all of the above mentioned adjustments to accomplish your modification, why mess with the design charateristics of the plane.
I cannot compensate with washers because its a side mounted engine. I already drilled the holes and I'm off the supposed centerline by only 3/32" which I'll assume its ok. If it seems awkward when I fly it, I'll just expand the screw slot on the mount a bit so I can slide the mount just a tad to compensate those 3/32"
Why can't you compensate with washers because it is side mounted??? The washers go between the engine mount and the firewall, not between the engine lugs and the engine. What you do is tilt the engine by putting more washers on the top than the bottom, or right or left by putting more on one side or the other. Just watch you don't screw up your thrust to badly.
By the way, you can't enlarge the holes enough to compensate for 3/32" That would put your screw holes about 1.5 times or more that stock size and you will probably run out of meat on the mount before you get it where you want it.
Don
Don
