RCU Forums - View Single Post - Two issues with my Axe
Old 10-20-2007 | 06:19 PM
  #88
MMatheny
Default RE: Two issues with my Axe
Been running all around today - besides, it was quite windy earlier, dying down now. Fixing to go out, a bit nervous though - rusty thumbs!
BTW, what kind of charger should I use for the Helimax TX if I put NiMH batteries in it? I tried my Futaba charger that only put out 9.6v and while it was charging if I turned it on the low battery light would always lite. However, once I unplugged the charger it didn't. I then found a 1000mh 12v transformer I plugged it into (the TX states 12v for the charger). These are 2000mAh batteries, so I figured keep it less than an hour or so on charges it should be ok - is there any kind of shut off circuitry in the TX so it won't overcharge?
