RE: Servo arm for a 600E
Something else I set mine up so that all measurements are equal and level. So that ball are adjusted in or out on the arm to insure they are level with the ball on the control arm. Also as stated earlier adjust to eliminate any binding between linkages. If one is just a little bit longer or shorter it will "buzz"
