ORIGINAL: exeter_acres
go ahead and set up idle up...it is easy
I agree with Exeter. Set up idle up. If you are anywhere near considering a loop, you are ready to be in idle up. After you get it set up, you will be amazed at how much better the heli behaves.
If you are above a basic hover, and you are flying outdoors, idle up is where you should be.
Vince
