RCU Forums - View Single Post - Bobcat 25
Thread: Bobcat 25
Old 10-22-2007 | 01:11 PM
opjose's Avatar
opjose
Default RE: Bobcat 25
ORIGINAL: Meekskin
Like I said before this is a great model to fly....My only problem is landing...it is a difficult plane to land...it slows down very quick and then it seems to lose the control surface. I have flown it 4 times now and not a good landing yet. I am using a 9x6 prop and I would guess it flies around 75 mph...it is quick and I really like the way it flies....not sure what I will do about the landing. Also, the takeoff is really smooth and easy...Great flying plane....
Ken
Yup it's not the same as a straight winger.
Even in Tumbler's video you can see that he is coming in hot. However he is landing on grass which slows the plane almost immediately.
When I do a similiar landing on asphalt, the plane takes about 500' to slow down enough to start turning it w/o scraping the wheels too much...
Adding "spoilerons" does help a lot for approaches.
Short of brakes, I'm also considering mixing in a "speed brake" setup that thows out all of the surfaces at once.
Doing so will be interesting as taking both rudders out, causes the plane to pitch up... so I need to get the right mix...
