building without hold downs
I think you will find that SOME SORT of holding method is IMPORTANT. Before my new table, I simply used masking tape and/or weights. Measured and checked eveything 4 times before applying glue. My new table allows the use of magnets in a bit diiferent way....see attached picture.
As long as the table you are building on is TRUE, your parts will be too.
