ORIGINAL: Eggert
Hello all, my first Hacker with 20 x 13 APC driven pattern ship, is about to be build. What will you recommend as side thrust ?
2, 2,5 or 3 degrees ?
There is no magic answer for side thrust. It is dependant on the model, airspeed, etc. I would recommend you start with the kit anufacturers recommended thrusts (down and side) and adjust from there during test flights.
If you are designing your own plane, I would research what similar designs are using and start from that information.
Good luck with your project.
Woodie
