Electric Pattern Aircraft Discuss epowered pattern aircraft in this forum
Hacker side thrust
Old 10-23-2007 | 05:08 AM
Default Hacker side thrust
Hello all, my first Hacker with 20 x 13 APC driven pattern ship, is about to be build. What will you recommend as side thrust ?
2, 2,5 or 3 degrees ?
Old 10-23-2007 | 10:13 AM
woodie's Avatar
Default RE: Hacker side thrust
ORIGINAL: Eggert
There is no magic answer for side thrust. It is dependant on the model, airspeed, etc. I would recommend you start with the kit anufacturers recommended thrusts (down and side) and adjust from there during test flights.
If you are designing your own plane, I would research what similar designs are using and start from that information.
Good luck with your project.
Woodie
Old 10-26-2007 | 02:04 AM
okay now, this thread is really coming alive
In the meantime I have found that despite the no magic it seems that most is working in the 2,5 degree range. Not 3, not 2, but 2,5
