RCU Forums - View Single Post - Tam A4 Build
Thread: Tam A4 Build
Old 10-23-2007 | 12:16 PM
tamjets
Default RE: Tam A4 Build
ORIGINAL: Stig Andersen
Hello Tam.
I just tried to install the main tank, but couldn't find a way in. Is there a trick or di I need to cut away a peice from the cockpit opening to get it into the fuselage.
Stig,
I can remember how to do the tank. Wait a minute. I'm flying on Lipo fuel. No tank needed.
Anyways,
John just explain it. You want the ducting able to remove for service.
The tank going from the engine hatch. The inlet ducting can be zap with CA after the tank install . That way you can easy remove the inlet ducting if need service.
ID:	788849   Click image for larger version
ID:	788850   Click image for larger version
ID:	788851   Click image for larger version
ID:	788852   Click image for larger version
ID:	788853   Click image for larger version
