Help with Thunder Tiger EB4 S2/S3
Hi everyone. I currently have a Thunder tiger EB4 S2. The old engine (thunder tiger pro 21) has been replaced with a new model. Only problem is the engine mount hole dimensions are larger on the new engine and wont fit the engine mount blocks. I would like to know if it is possible to fit the EB4 S3 engine mounts as they are meant for longer engines. I think the spacing might be the same, but would appreciate if someone could measure the distance between the holes on the underside of a S3 mount.
Thanks for your help
Alistair
