RE: Attitude on the Ground?
Grits: I solved the same problem on a new trainer by just going to the next larger size main wheels. The 3" wheels will work better on the grass runway. If you are not flying on a grass runway, going to a size smaller on the nose wheel will also give you the 2-3 degrees nose down attitude.
AERORICH73
