ORIGINAL: marc s
Stig.
Hope you dont mind an observation but you may find it easier to get all the wiring and cable runs in from the rear of the jet to the front section first, while you have good access to the fuselage bottom, before fitting the tanks.
Looking at the manual and build threads this seems the best method and less hastle, especially as the runs are either side of the main tank.
marc.
Hello Marc.
Thanks for the advice, but I mounted the tanks with silicone yesterday and I found today, that there is enought room to run the air hoses and the servo leads on either side of the main tank. I made sure that there is approx. 10 mm between the fuselage and the main tank on either side. Using my Dremel, I made a hole in the bulkhead where the leads and hoses can pass through. I think it is OK.
BTW, Tam. Where do I put the UAT?
Here are some pics.
