ORIGINAL: KC36330
i put my fuel pump, smoke pump, ECU batt and Duralite batt all in the nose cone and had the UAT under the cockpit floor, balance worked out perfect.
OK. Thanks for the advice. I figured that the model neede weight in the nose, but I'm confident that I can put all my gear in the nose section to avoid having to use lead for balancing.
