RCU Forums - View Single Post - GIANT stinger g62 help!
Old 10-24-2007 | 07:20 PM
aussiesteve's Avatar
aussiesteve
Default RE: GIANT stinger g62 help!
I have the ARF version of it here with a DL50 on the front. I used TowerPro servos (heavy-ish) mounted in the tail (stock location for the ARF). It balances ok - JUST. I mounted the battery pack as far back as I could also.
I suspect that you will have more joy if you cut a little off the front if you're using a G62. I'm guessing you are kit building it?
