RCU Forums - View Single Post - the hyper st PRO thread!
Old 10-25-2007 | 07:11 AM
  #55
ttoks's Avatar
ttoks
Default RE: the hyper st PRO thread!
i've driven both the hyper and the losi, given the both are the RTR versions, not the roller and pro, but really there isn't much in it, both were using stock setup except 37.5 WT oil in the rear of my 8ight and some toe adjustments in the front, the hyper is a bit easier to drive with the stock setup, the 8ight it very over steer oriented, likes to swing the rear end out both under brakes and power, but if you can get used to power sliding it the losi is fast, the hyper is easier to drive fast then the losi though.
