RCU Forums - View Single Post - Help with Dynahawk helicopter
Old 10-25-2007 | 08:22 PM
Druss
Default RE: Help with Dynahawk helicopter
dbcisco has it right, with only two channels you can only control two aspects of movement. The first will be throttle and because it's a fixed pitch the amount of list you get is completely controlled by how much throttle you give it. the second channel is rudder or spin. you will not be able to both hover and get forward movement, i suggest adding the weight to the front to get forward movement as that's more fun than hovering in place and spinning in circles.
The advertising is misleading when it says it can move forward, back, left and right. You need 4ch to do that.
