RCU Forums - View Single Post - Using CA
Thread: Using CA
Old 10-27-2007 | 04:47 AM
mclina's Avatar
mclina
Default RE: Using CA
Like has been said, if you can tolerate the CA fumes, it builds very strong wings. You just need to be sparing with it, because it is not sandable, and will leave bumps in your finished model if it drips. I stopped using it, except in places where I need a quick hold and I can't easily pin something to shape, such as odd-angles, etc. If a drop accidentally dries where I don't want it, I shave it off with a razor rather than trying to sand it.
Make sure you use it in a well ventilated area, where the fumes are drawn away before they get to your face, and your tolerance for the stuff will last much longer.
Good luck.
