RE: Using CA
As mentioned the CA glues will work just fine for the wing ribs. You also want to get a thicker CA, also known as gap filling, as this will allow you some working time to make a minor adjustment if needed. They also make an accelartor for CA glue that you can spray on the thicker CA glue's to aid in drying once you have the parts the way that you want them. Good Luck, Dave
