RCU Forums - View Single Post - Using CA
Thread: Using CA
Old 10-27-2007 | 08:27 AM
Dr1Driver
Default RE: Using CA
CA is by far the best, strongest, quickest and easiest method of building. Use thin CA on balsa to balsa joints and thick on plywood. Use a combination on balsa to ply.
Hold the pieces in place, place a drop about every 1/4" - 1/2" along the joint line, and hold for about 15 seconds. On ply to balsa joints, use thin first and let it soak into the joint, then follow with thick.
Dr.1
