Run-in procedure
Hi
Does someone have a good run-in procedure for 2 stroke ABC engines. Manufacturer recommendations vary from brand to brand quite radically. Certain manufacturers recommend 10 seconds alternating between 2 stroke and 4 stroke sound. Others recommend just-on 2stroke for a full tank. Others recommend running for 2 minutes at a time with cool down in between. So many options.
Surely ABC behaviour is fairly standard and the run-in procedure should also be standard. Is there a good general rule that will guarantee best bedding-in of components
regards
Hedley
