RCU Forums - View Single Post - Re: Powerbox & DSC?
Old 10-27-2007 | 12:57 PM
BrunoCH
Default RE: Re: Powerbox & DSC?
If you connect the signal wire input of the DSC harness to the receiver, it should work as normal. I think the connector that goes to the switch is only used to check the battery voltage.
At the last Euro Champs, CPLR was using a 4 cell NiCD pack and a normal switch.
