ORIGINAL: kyo crane
Thank you Mazdab2600 for your advice.
But the standard deflault which comes with the package is 0.7mm, for a smooth enage.
And a 0.9 to 1.0 mm is for aggressive response.
thank.
if the gear is turning.your springs are not set right on the flywheel nut or the idle is to high and the shoe's are rubbing on the clutch bell.
thats all i cant think of with the parts you've listed/changed.
