RCU Forums - View Single Post - need help regard hellfire
Old 10-28-2007 | 08:47 AM
Briansshop's Avatar
Briansshop
Default RE: need help regard hellfire
ORIGINAL: mazdab2600
the k4.6 is a torquey motor.
i think you should have used 1.0/1.1 mm clutch springs.
the .9mm are weak and your clutch is likely engageing while trying to start causeing the gears to turn.
my savage x f4.6 uses the 1.0mm that come with the hpi alloy shoe's.
my lrp spec 3 is using 1.1mm springs.
Yea,I used the 1.0mm springs{gold,I think}and no "weights" in the HPI alum shoes.Works nice.Kyo, sounds like maybe you don't have the springs installed right if your wheels turn w/the starter.
